2007 silverado misfire (no codes) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
  #16 (permalink)
Old 04-30-2012, 09:33 PM
So, the miss fire came back, Codes P0300 and once it did a P0304. this seems to happen then im in park and hold the RPMs at 2000 for 10 sec's. and ideas?
  #17 (permalink)
Old 05-02-2012, 08:38 PM
sbchevfreak's Avatar
Licenced Automotive Technician
It may not have anything to do with the stereo, with what you have mentioned. You may need to have a Crank Angle Sensor Error relearn done. IIRC, this will require a Tech II scan tool.....
  #18 (permalink)
Old 05-02-2012, 08:40 PM
I actualy was just at chevy and they told me the same thing, its going in tomorrow. will keep ya updated :
  #19 (permalink)
Old 05-03-2012, 06:15 PM
So, it turned out that the previous owner put in cheep spark plugs and that was the reason for the miss..... I dont know why you would change the plugs on a truck that only had (under) 60,000kms on it... but nothing 300$ cant fix...
  #20 (permalink)
Old 05-03-2012, 06:22 PM
LATECH's Avatar
What brand were they? Let me guess...CHAMPION?
Fact is stranger than Fiction
  #21 (permalink)
Old 05-03-2012, 06:23 PM
NGK plugs....
  #22 (permalink)
Old 05-03-2012, 06:27 PM
LATECH's Avatar
Wow, who would have thought , but then I would not have put NGK in a chevy anyhow. Kinda goes against the grain you know.
  #23 (permalink)
Old 05-09-2012, 02:59 PM
This will really bake your noodle.....
NGK makes some of AC Delco's plugs.....
I near crapped when I pulled out a set of factory plugs from a 5.3 in a p/u, and they had an AC Delco number on one side of the porcelain, and an NGK number on the other side!
  #24 (permalink)
Old 05-09-2012, 03:51 PM
LATECH's Avatar
EEK!!! I guess I should expect it. After all AC delco was first supplied with spark plugs made by Albert Champion. Then GM bought the rights to the name, incorporating it into AC Delco. Kinda scary huh?
I put a set of NGK plugs in a 2000 forerunner today as the Denso plugs that were listed, were not a twin electrode style. The engine had a tag on it specifying Only twin electrode plugs. Dont need a pesky P0300 popping up after a tune up.
Recent Modern Electronic Engines posts with photos
2007 silverado turn signal speden Electrical 2 03-29-2011 04:25 PM
04 5.3 silverado misfire 10Tonhammer Engine 3 10-28-2009 11:51 PM
2007 Chevy Silverado 3500 Dualie Front Brake Rotors Rob Keller Suspension - Brakes - Steering 2 09-12-2008 07:15 PM
2007 Rod & Custom Americruise 2007 pictures posted wp442 Hotrodders' Lounge 2 07-04-2007 12:59 AM
SPY(ish) PICS! 2007? Chevrolet Silverado 1500 ChevelleSS_LS6 Hotrodders' Lounge 8 09-04-2006 02:35 PM
