2008 malibu front suspension clunk - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2013, 08:38 AM
What is causing the clink/creaking in my malibu front end. Note My 200 monte carlo had the same noise.
Old 01-05-2013, 12:18 PM
LATECH's Avatar
Classic GM problem. Its a sloppy design built in to the collapsable steering shaft in the steering column.
Seen it lots of times. Its not unsafe, just noisy.
There is service bulletins for the problem, and it requires the lower half of the steering shaft be replaced.
On a 2008 you might get it fixed free, if you dog the dealer where you bought it. Take a copy of the service bulletin with you, or they will do there best to dodge the issue.
Fact is stranger than Fiction
Old 01-05-2013, 02:30 PM
thanks I will follow up.
79 malibu front caliper INSTALLATION help wiser626 Suspension - Brakes - Steering 1 06-28-2009 07:59 PM
79 malibu front caliper removal help wiser626 Suspension - Brakes - Steering 3 06-26-2009 09:35 PM
79 TA, clunk, clunk, clunk sounds under hard steering Gladis Suspension - Brakes - Steering 13 05-01-2007 07:34 AM
79 malibu suspension fast79malibu Suspension - Brakes - Steering 3 01-01-2007 03:57 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
