2009 ford escape - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2013, 06:54 PM
2009 ford escape
engine miss. changed coils due to error codes, cleaned maf sensor, going to tps next and maybe idle air. still getting 22 mpg. any suggestions for the misfire I am getting? coders do not indicate coils or plugs. plugs also changed.
Old 09-09-2013, 07:00 PM
LATECH's Avatar
So you are getting misfire codes?
Fact is stranger than Fiction
Old 09-11-2013, 08:50 PM
dklong's Avatar
newbie you have to watch out on those 3.0 l escapes if you took off all 3 igniton coils, people are getting #4 and #6 coil connectors hooked up wrong, the wire harness for the coils lays over the valve cover , not along the edge of the cover, with it going along the edge of the valve cover #6 coil plug in lays beside #4 coil and the same with #6 coil is beside #4 coil plug
'03 escape fwd axle nut.. delawarebill Suspension - Brakes - Steering 4 12-22-2012 12:30 PM
wear spot in carpet below foot rest Ford Escape Duntov Interior 2 09-03-2010 12:01 PM
Back to the 50's 2009 RODDER18 Hotrodders' Lounge 9 06-22-2009 12:02 AM
