200r or 700r - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2012, 03:25 PM
200r or 700r
I have a 89 caprice with 26 inch rims the car got a 2004r in and I have tore it out....I wanna know if I should get it rebuilt built up to hold 600 hp or should I go wit a stock 700r
Old 02-25-2012, 11:18 AM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
Neither one of those trannys will hold up to that kind of power without extensive modifications to the internals. Especially a stock 700R4, they were only rated to about 350 HP.
Check out "Extreme Automatics" and "700raptor.com"
Old 02-26-2012, 08:24 AM
S10xGN's Avatar
Gotta love a turbo!
I'm partial to the 200R4, I have two built to hold plenty... You didn't state your location, but there are several premier builders in the US that will out-build anything you can get from Extreme, Raptor, Gearstar, B&M, TCI, etc. Either way, plan on paying $2500+ for it.
Russ
700r for a 200r marlon walker Engine 4 07-21-2010 04:51 AM
Gm 200r-4 345 desoto Transmission - Rearend 3 08-25-2008 11:42 AM
200r ntrkooled Transmission - Rearend 3 05-29-2008 12:34 AM
200r/700r trans. chiefs51merk Transmission - Rearend 4 09-08-2005 10:24 AM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
