Hotrodders Bulletin Board > Tech Help> Transmission - Rearend
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 02-26-2007, 07:45 AM
Eric64 Eric64 is offline
200R speedo gears
I've got a TH350 now and was thinking of putting in a 200R it's the earlier model with the mech. speedo cable, Can you change the speedo drive gears like in the 350? I changed the gears in that one to match the tires/wheels but that one had the removable tail shaft. Thanks for any help. Eric
  #2
Old 02-26-2007, 09:31 AM
joe_padavano joe_padavano is offline
Actually, changing speedo gears on a 200-4R is even easier than on a TH350 or TH400. The driven gear is in the speedo cable output housing, just like on a TH350/400. Pull cable, remove one bolt, and the housing pulls right out.
The speedo drive gear is actually on the governor, not on the output shaft. You access the governor by dropping the pan. With the pan off, you'll see a small bolt-on cover at the back of the case. Unbolt the cover and the governor pulls right out. A snap ring holds the drive gear on the governor.
Old 02-26-2007, 04:48 PM
Thank you for the info I just wasn't sure how much of a pain it was or if it could be done. Thanks, Eric
Old 02-26-2007, 05:32 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
The trouble with the 200R4 speedometer gears are they ALL seem to be frozen into the case.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "200R speedo gears"
ThreadThread StarterForumRepliesLast Post
700r4 speedo questionJmarkTransmission - Rearend210-08-2006 09:33 PM
TH 400 Speedo Gearsrs67ssTransmission - Rearend504-04-2005 12:58 AM
Speedo calibrationnovatechTransmission - Rearend202-12-2004 08:46 PM
speedo drive gears for muncie345coupeTransmission - Rearend309-21-2003 08:11 PM
Speedo not working..4spdTravTransmission - Rearend507-31-2003 02:21 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
