200r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2006, 06:52 AM
MI2600's Avatar
Member# 3287
200r4
Previous info from members here stated that I can install a 200R4 and just run 12v to the "A" terminal to get the lock-up feature to work. That's the way I've wired my '72 project (with an inline rocker switch).
Yesterday, I was reading some material which said to also loop wire the other two connectors together (one terminal in the plug isn't used).
Can anyone clarify?
Old 10-29-2006, 11:51 AM
airworld2's Avatar
200 4r
you need 12 volt positive terminal a
and the one directly behind a is d needs to be ground can be to pan or toggle switch,
B C
A D
This will be the plug as it sits in the case
front of car, there are a few options
Old 10-29-2006, 03:49 PM
2004r
Hey airworld2,we use a low vacuum switch in series with [A] wire,so that when you tip into throttle vacuum change creates open in circut and unlocks converter.Have you used this setup? Or do you use another system.If so I welcome your input,as we do a lot of 3 speed- overdrive conversions at my shop.Thanks in advance,Briscoe.
Old 10-30-2006, 06:53 AM
airworld2's Avatar
200 r4
the easy as low cost way is to wire a to hot and ground solenoid to n/o forth gear switch, you only need lock up in forth . 700 can be the same or other combination
Old 10-30-2006, 06:01 PM
2004r
Thanks for input airworld2.I'm curious,do you get many requests at your shop for 3spd to overdrive conversions? Briscoe
Old 10-30-2006, 08:57 PM
Crosley's Avatar
Wiki Edits: 1659
you can patch into the gov feed circuit and use the ol gov pressure switch off a t-350C unit..... requires some drilling and tapping to hook into the gov circuit on some/most 200-4r
remember how in the early days the diesel cars with a t-350C would lockup the converter at like 35 mph and the diesel motor would do some chugging? Car owner would be sure something was wrong.
ah the good old days.....
Old 10-31-2006, 06:32 AM
airworld2's Avatar
200r4
I do 700 install's when ask to last one a couple of weeks ago.1970 chevy pu
from 400 to 700
Old 10-31-2006, 07:03 AM
2004r
You know Crosley,an optimist would consider these the good old days,however I sure miss those 350s,400s c-4s etc.I use to build 3 a day,almost every day,never thought it would end .Now back to the thread.Have used those methods as well to obtain ,or delay lockup,in fact I have a booklet somewhere which gives instructions for lockup on a lot of different trans,will see if I can find and post that info.
Old 10-31-2006, 09:02 PM
Crosley's Avatar
Wiki Edits: 1659
I still work with those trannys.......
for some reason we are trying to make a power glide live behind 1500 to 1800 hp in monster trucks nowadayz
I am an optimist ; I am positive something will go very wrong......... daily
200R4 to TH350 JohnyR17 Transmission - Rearend 4 10-18-2006 11:43 PM
200r4 79 Malibu327 Transmission - Rearend 1 07-27-2004 12:40 AM
Turbo 350 or 200R4? Forsaken502 Transmission - Rearend 14 12-09-2003 10:11 PM
200r4 oldsmo Transmission - Rearend 1 09-27-2003 07:03 PM
200r4 Zeder Transmission - Rearend 5 09-10-2003 09:17 PM
