200r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2007, 04:09 PM
200r4
I'm looking for a 200R4 transmission. I've looked on Ebay and found nothing. I understand that the 200R4 is the same size as a TH350 transmission.
Old 02-27-2007, 04:26 PM
car builder
Look at some mid 80s camaros in a salvage yard.
Old 02-27-2007, 04:46 PM
Last journal entry: car is painted
I don't think camaros came with them. I got mine out of an 87 cadillac. You want one out of an 86 or 87 car. If this is for a Chevy, be careful. Most of them have a B-O-P bellhousing. You would need the multi-fit case. If you want a rebuilt one, try Bowtie overdrives. I bought some parts from them.
Old 02-27-2007, 07:13 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Originally Posted by MIKE FROM SM
Most of them have a B-O-P bellhousing. You would need the multi-fit case. .
I disagree. With the exception of a rare early (1982) few that were BOP-only, all 200-4rs are dual-fit housings. You're looking for 82-90 cars.
Look to:
-pretty much any BOP (or Caddy) car with OD. Most chevy cars with chevy engines got the 700r4 as the OD option, but most other GM cars (even if they had chevy engines) often had the 200-4r as the OD option. Almost all OD RWD caddys (regardless of whether or not it had the 4100, the 307 olds, or the 350 chevy) has a 200-4r.
-Almost all A/G bodies had them; cutlass, grand prix, grand national, Monte Carlo, and Bonneville (during the years that they were A/G bodies). Some El Caminos and Malibus had them as well, especially later in production.
-Almost all B/D bodies that were not chevy had them. Fleetwood, Olds 88 and 98, Bonneville, and Buick Electra
-Late-80s turbo trans ams had them behind the turbo 403 olds.
Here is an excellent site with tons of 200-4r links. http://members.aol.com/powerrslid/thm2004r.html
Old 02-27-2007, 07:27 PM
Thanks for all the info.. How about the fit between a th350 and a 200r4?
Old 02-27-2007, 08:00 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 200-4r is the same length as the t-350 that has a 6 inch tail housing on it.
the trans mount area on the 200-4r is further back than the t-350.
The TV cable hook up on the 200-4r is very important.
Old 02-28-2007, 02:07 PM
fast68's Avatar
likes chevy trucks & boobies
im sorry but there were no 403 engines in any F bodies after 81
http://sethirdgen.org/faq.htm
What tranny do I have?
-First you need to determine if its a manual or automatic transmission. If its an auto, there were two available. The 200C and the 700R-4. Only early(82-83) thirdgens had the 200C, and it was a three-speed, so if you have a 3 speed auto, it was a 200C (not to be confused w/ a 2004-R) and if it was a 4-speed auto, it was a 700R-4/4L60 (not to be confused w/ a 4L60-E). There were also a 4-speed manual and a 5-speed manual. Only the early thirdgens('82-83) had the 4-speed manual
http://en.wikipedia.org/wiki/Third-g...evrolet_Camaro
http://en.wikipedia.org/wiki/Pontiac...2.80.931992.29
http://www.thirdgen.org/tech-data
http://www.thirdgen.org/1982-pontiac...982_drivetrain
http://www.thirdgen.org/1983-pontiac...983_drivetrain
http://www.thirdgen.org/1983-pontiac...984_drivetrain
http://www.transamworld.com/fbird-history-php3.php
all 82-92 were chevy powered
also none came with a 2004R
the 82 and 83 came with the 200c and no other auto
late 83 and up were either 700r4 or t5
2004r was G body and other models
i own an 82 trans am WS7 5.0 200C converted to th350 and have owned many different third gen f bodies
find the 200r4 in the montes and cutlasses and other cars
but none were in the camaros or firebirds, as they got the 700r4 instead
ppl need to know facts before posting false info to ppl
Old 02-28-2007, 04:58 PM
jakeshoe's Avatar
Sounds like you need to get YOUR facts right before posting false information then.
3rg Gen Pontiac F-Body TTA 1989-1990 models came with a 200-4R. A very good core to use for high performance use at that.
They also had a Buick motor.
http://www.thirdgen.org/1989-pontiac-firebird
http://en.wikipedia.org/wiki/Pontiac_Firebird
Old 02-28-2007, 09:10 PM
While I WISH there was a Turbo 403 Olds motor, you are mistaken. The only turbo motor ever built by Olds was the Jetfire aluminum 215 V8 sold in 1962 and 63. The 403 was normally aspirated and was only built between 1977 and 1979. There was a 2nd gen Trans Am turbo based on the 301 Pontiac motor and used as the Indy Pace Car in 1980. There was also the 3rd gen Trans Am turbo that used the Turbo Buick V6 (as noted in the previous post) and that was the Indy Pace Car in 1989.
Old 03-29-2007, 09:57 PM
I got mine from an 84 old cutlas supreme
Old 03-31-2007, 01:32 PM
RippinRon's Avatar
Try searching 200-4r not 200-r4. My 86 cutlass had a dual bolt pattern 200-4r behind a 305 sbc.
200R4 to TH350 JohnyR17 Transmission - Rearend 4 10-18-2006 11:43 PM
Turbo 350 or 200R4? Forsaken502 Transmission - Rearend 14 12-09-2003 10:11 PM
replaceing a 200r4 with a 700 r4 edwards_305 Transmission - Rearend 3 11-04-2003 10:25 AM
200r4 oldsmo Transmission - Rearend 1 09-27-2003 07:03 PM
TH 350 to 200R4 bigjoedo Transmission - Rearend 1 05-02-2003 09:04 AM
