200r4 or 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2003, 03:40 PM
'87 monte ss's Avatar
New Member
200r4 or 700r4
Whats the diffrence between the 200r4 and the 700r4 and how can you tell if its electric shifted or not?
Old 10-16-2003, 04:34 PM
Mainly the gear ratios. IMHO
Go here......http://www.tciauto.com/tech_info/gear_ratios.htm
Some folks like the 700 better.......
The 200 came out first.....
Old 10-16-2003, 05:19 PM
New Member
the higher the ratio the lower its geared right? so would that make the 700 geared lower
Old 10-16-2003, 09:33 PM
True..........but only by 3 %
.067 verus .070 in overdrive
A true 87 SS should have a 200R4 already in it from the factory..........
Old 10-17-2003, 03:33 PM
New Member
it does but if the 700 is built better or stronger or more higher performance i'll get one of those
Old 10-18-2003, 12:22 PM
dr. nomad's Avatar
The disadvantage of the 700R4 is that there is a wide split between 1st and 2nd gears, producing a bigger rpm drop; the ratios are 3.06, 1.63, 1.0, and 0.67. The TH350 has 2.52, 1.52, 1.0. The 200R4 is inbetween at 2.74, 1.57, 1.0, 0.67. Strong 200R4's can be built; that's what's hooked to most Buick GN's.
