200r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2006, 06:12 PM
200r4
hi everone.my 442 has200r4 trans this will be the third 200 in my car.what to switch to aturbo 350 rear has 373s is this a mistake not happy with 200 also what is the best shift kit?easy to install? thanks!
Old 09-30-2006, 09:32 AM
willys36@aol.com's Avatar
Wiki Edits: 21
What keeps breaking in your trannys? There is something wrong in your system to be losing them like that. 200R4s are very good units and can take a lot of HP. One thing that all these OD trannys have in common is the throttle linkage. You can't set them by ear like you can w/ 350s. They MUST be set w/ a pressure gauge testing pressure at several running conditions.
I suggest contacting BowTie Overdrives with your problem. They are very helpful and really know their stuff. Their web address is http://www.2004r.com/ so that must tell you something!
200r4 79 Malibu327 Transmission - Rearend 1 07-27-2004 12:40 AM
Turbo 350 or 200R4? Forsaken502 Transmission - Rearend 14 12-09-2003 10:11 PM
replaceing a 200r4 with a 700 r4 edwards_305 Transmission - Rearend 3 11-04-2003 10:25 AM
200r4 identification tnoftsger Transmission - Rearend 1 10-21-2003 05:32 AM
200r4 oldsmo Transmission - Rearend 1 09-27-2003 07:03 PM
