200R4 Capacity - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2008, 04:25 PM
MI2600's Avatar
Member# 3287
200R4 Capacity
Off the top, does anyone know the oil capacity of the 200R4?
Old 10-18-2008, 04:34 PM
If you mean a Turbo Hydromatic 2004R, I believe it's roughly 23 pints.
Old 10-18-2008, 04:52 PM
XNTRCI-T's Avatar
AKA Lee in KC
TCI Chart You'll also need to factor in the cooler and its lines, if you have one.
Old 10-18-2008, 05:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a deep trans pan will affect quantity needed.... smaller stall speed converter?
1 quart in the converter... install 4 qts in the trans, start the engine... add 4 more... check fluid height, check trans for engagement into gear.
Add fluid to proper level on the dip stick = hot or cold
Old 10-18-2008, 09:48 PM
MI2600's Avatar
Member# 3287
Thanks, guys. I didn't want to overfill. Just swapped in a new(er) trans.
Old 10-19-2008, 07:42 AM
AXEMAN39's Avatar
Bone dry stock tranny and converter mine took 16 quarts.
Swap 200c for 200r4 DieselCutlass Transmission - Rearend 17 09-11-2008 01:14 PM
200r4 mitchc Transmission - Rearend 2 08-06-2007 08:13 AM
Street Rod Alternator Capacity? JohnTN Electrical 2 11-27-2004 04:41 PM
Turbo 350 or 200R4? Forsaken502 Transmission - Rearend 14 12-09-2003 10:11 PM
200r4 oldsmo Transmission - Rearend 1 09-27-2003 07:03 PM
