200R4 Converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2006, 02:52 PM
MI2600's Avatar
Member# 3287
200R4 Converter
I just wrestled the 200R4 into the '72. The trans was from an Olds. When I went to bolt up the converter, it was about an 1/8" off from the 400 SBC flexplate...?
I've got another 200R4 from a Monte Carlo behind another 400 in my '86 and it bolted right in.
Was/is there a difference in the BOP and Chevy converters?
Looking for solutions.
Old 08-09-2006, 03:12 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
What do you mean by off by 1/8"?
I had a 200R4 from a Monte SS that was a duel pattern housing, it first went behind a Buick 3.8 turbo then later it went back behind a Chevy. The convertor bolted up fine behind ea.
Old 08-09-2006, 08:33 PM
MI2600's Avatar
Member# 3287
The bolt holes in the converter are about 1/8" closer to the center of the converter than the holes in the flexplate.
I was wondering about extending the flexplate holes with a die grinder...?
Old 08-10-2006, 08:46 AM
MI2600's Avatar
Member# 3287
Anyone see a problem with extending the holes equally?
I suppose super glue is not an option.
Old 08-10-2006, 04:07 PM
MI2600's Avatar
Member# 3287
No responses? Bump
Old 08-10-2006, 09:40 PM
MI2600's Avatar
Member# 3287
Good news. I had two 400 flexplates and just grabbed one. Tonight I looked at the other one and it has a dual converter pattern.
Don't you just love when it all (well, almost all) comes together.
Old 08-11-2006, 06:34 AM
1ownerT's Avatar
Wiki Edits: 4
Glad you found an easy fix, I had to get out where my 3.8 is stored to check the flexplate, it has the duel pattern.
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-26-2004 11:32 PM
what does lockup mean 67bird Transmission - Rearend 31 02-25-2004 10:21 PM
Turbo 350 or 200R4? Forsaken502 Transmission - Rearend 14 12-09-2003 10:11 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 06:53 PM
