200r4 intermittent up shift to soon - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2006, 04:59 PM
66ImpSS396's Avatar
It's been fun
I have an 89 Chevy caprice 305 efi 3.08 gears all stock 140kmi, the transmission has developed and intermittent problem. This is the first problem I've had with the car. Intermittently the transmission will shift up through the gears to OD at about 5mph (starting from a stop under light acceleration) nearly kills the motor. You can force it to down shift by pushing the peddle to the floor or pulling the shifter down to a lower gear. I have tried driving in drive rather than od but then it will just shift up to drive. It will also try not to down shift during breaking until it gets down to 5 or so then it shifts down with a thump. May have this problem two or three times in a row then not again for several days. Pulls good no slipping or other odd behavior
fluid and filter has been changed regularly, and has been changed since the problem started. Other than that automatic transmissions are "FM" to me.
Any Ideas would be appreciated.
Old 07-13-2006, 05:02 PM
jakeshoe's Avatar
Check for proper TV cable adjustment, it may have moved to a lower setting.
You may have a sticking TV valve in the VB. Broken TV plunger spring, or other VB problem.
Check the cable first.
Old 07-13-2006, 07:35 PM
airworld2's Avatar
200 r4
sounds more like tcc solenoid trouble, drop the replace it and test drive again
airworld2
Old 07-14-2006, 09:45 AM
66ImpSS396's Avatar
It's been fun
200r4 shift
Thanks!
I'll try both suggestions. I've got the shop manual it doesn't look to complicated to do. I'll round up the TCC sol, ATF and filter. I'll get back on the results. Thanks again to you both.
Barry
TH 350 1-2 Manual shift Feel HarderTranz Transmission - Rearend 3 05-16-2006 10:20 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 11:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 10:08 PM
Stall wrong, transmission shift adjustment, suggestions? frankenvette Transmission - Rearend 3 10-26-2004 12:59 PM
