200R4 line fitting sizes... - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 03:44 PM
S10xGN's Avatar
Gotta love a turbo!
Hi All,
I'm about to buy a B&M supercooler and need to get from a -6 line to whatever size the fittings are on the 200R4 case. What fitting do I need? Is it the same as all GM trannies?
Thanks!
Russ
Old 02-18-2009, 11:50 PM
SSedan64's Avatar
Pretty sure the trans case fittings are 1/4"NPT to 5/16" inverted flare. So 1/4"NPT to -6AN should work.
Old 02-19-2009, 05:52 AM
S10xGN's Avatar
Gotta love a turbo!
Thanks! For some reason, I had it in my mind they were machine-thread with sealing washers.
Russ
Old 02-19-2009, 06:10 AM
SSedan64's Avatar
Russ
Russ,
To be sure try a search on the TurboBuick.com forum, or I will if I can find it. The one 2004R I swapped fittings on was 1/4"NPT but someone could have been there before me. I know just about everything else on the 200's is metric.
Todd
P.S. I found it here.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
http://www.turbobuick.com/forums/tra...-fittings.html
Old 02-19-2009, 06:14 AM
SSedan64's Avatar
Also the the 2004R's line fittings are the reverse of other GM trans. The top is out to cooler & bottom is return from cooler.
Welding on Quarter Panels mightycarlo10 Body - Exterior 9 04-02-2008 10:16 AM
terrible gas milage help!! hddave1 Engine 124 03-31-2008 11:57 AM
Brake line size - can it be TOO large? cboy Suspension - Brakes - Steering 20 03-20-2008 09:51 AM
Brake Line - 3 way fitting, one way only? BIGSKY Suspension - Brakes - Steering 2 11-17-2005 03:30 PM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
