Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-12-2008, 01:46 PM
redbandit98 redbandit98 is offline
200r4 lockup problem
hello all, I have a problem. I have the 200r4 tranny in my 85 ss monte carlo. I recently took out the computer and have since switched the lockup control over to a manual switch in the car. I have done this setup on three different vehicles ive owned and never had a problem. The problem is once i lock the solenoid, it will stay locked up even with power off to it. The transmission seems to shift fairly hard, but the owner claimed it has always done this. (older guy and very honest about everything on the car). Recently, i had all new transmission seals installed. (it was leaking BAD) The car had set forever and the seals had dry rotted i guess. He put new seals in everything. He even put me in one new band because he said it was a little burnt. I had him put me in a brand new lockup solenoid since i figured that was why it was sticking to begin with and it would be a perfect time to replace it. Well, i got the car back and the tranny shifts great, doesnt leak at all, but the damn solenoid still sticks. I can drive it around forever, but once i lock it, it will stay locked until i shut the car off for a while and i guess the pressure lets whatever is sticking un-stick. I dont know what is causing this. I mean it drives great, shifts great, and the lockup works perfect when i hit the switch. Its just when i go to unlock it, its still locked.
Old 05-12-2008, 02:28 PM
Rick WI Rick WI is offline
re: 200r4 lockup problem
Sounds like a sticky solenoid switch. Need to drop the pan to replace. NAPA has them.
Old 05-12-2008, 03:31 PM
solenoid switch? So your telling me there is a switch that controls the actual solenoid? I have replaced several solenoids, but never a switch. Some sort of pressure switch i presume?
Old 05-14-2008, 12:01 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
JackOfAllTradesMasterOfNo ne
Did you do the external manual lockup conversions or the internal? If internal type is uses the 4th gear pressure switch on the bottom right side of Valvebody that may be sticking.
Old 05-14-2008, 06:03 PM
briscoe briscoe is offline
2004r
When the 1-2 shift valve strokes it supplies fluid to the TCC circut.
But only when the 1-2 valve moves to the upshifted position.The fluid "supply" is shut off when the valve moves back to the downshifted position, so as not to allow lockup in first.
Therefore you can not achieve lockup until this occurs, unless the TCC solenoid is faulty and allows the lockup valve to stroke or stay applied even after the 1-2 valve has reached the downshifted position.
A very common failure at one time, the solenoid would fail and flood the TCC circut, thereby causing the TCC lockup valve to stroke to the lockup position.
Coasting to a stop and feeling a jerking situation was a common symptom which indicated a TCC solenoid that was not releasing it's supply of fluid and in essence hydraulically applying the TCC lockup valve.
Old 05-15-2008, 01:29 PM
well, its not locking up in first. I mean I can come to a light, and the car doesnt jerk around like its locked up. I know what it feels like becuase on my old truck i would sometimes forget to unlock it and it would almost stall. As soon as it shifts though you can tell its locked up and will stay locked up through all the gears and even with the power to the switch off.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "200r4 lockup problem"
Weird TCC problem blacklabzeke Transmission - Rearend 16 05-15-2008 12:07 AM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
help troubleshooting 89 350 TBI problem? Chuck78 Engine 12 02-04-2007 07:08 PM
200r4 problem 406 ss monte Transmission - Rearend 2 01-04-2005 09:28 PM
