Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200r4 to LQ4 (steel block LS)
Old 05-26-2007, 08:24 PM
S10xGN's Avatar
S10xGN S10xGN is offline
Gotta love a turbo!
Originally Posted by olds79
...elongate the bolt holes in the converter to hook everything up. I dont if its just me or does that sound like it would comprimise the integrity of the driveline...
thanks guys!
I can't imagine it weakening anything. Remember, (hopefully) you'll be torqueing those bolts to 50+ lb-ft. If it still bothers you, rotate the flywheel (in the direction of rotation) up against the edge of the "slot" so it's loaded, then tighten the bolts.
Russ
