200r4 Manual Valve upside down? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2006, 11:56 PM
I just finished reassembling 200r4 Valve body. Cover not on yet
Tranny is upside down on blocks.
I can't remember how the manual valve looked.
I have the linkage from the shift level throught the whole in the manual valve.
Can it be installed upside down?
When I work the linkage the back end of the valve (toward rear) has a cut groove showing upward. Should it face down
Old 08-25-2006, 12:27 AM
My mistake
Second look and the hole for linkage doesnt not go all the way through.
Can only be installed one way.
I am a bit nervous on my first automatic shift kit install
Old 08-25-2006, 01:10 PM
S10xGN's Avatar
Gotta love a turbo!
YUP, I got mine in "upside down" and everything back together before finding that the linkage would only shift ftom park to reverse! Had to partially disassemble and flip it over.
Russ
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 01:48 PM
Is this (bigger) valve sitting right afte the new seats and valve job? sizemoremk Engine 16 12-11-2005 12:18 AM
Ford's Using Manual Valve Bodies Stock? offroadin Transmission - Rearend 2 02-04-2004 07:06 PM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
