The shifter will come wirh the bracket. Make sure you select a 4 speed shifter. The 4 speed shifters can be converted into three speeds if desired. The shifter comes with a slew of brackets for different applications. On gm the same bracket is used but a different hole is used for 4 speeds. If you buy a used shifter make sure you get all the parts. I use a quicksilver and love it. I swap transmissions every now and then and it is very easy to change from 4 speed mode to 3 speed mode. Also it meets lockout requirements without the trigger; makes a very neat and tidy interior. Plus with adapters most shift knobs will fit.
Thanks, ethn_bert.
I have a used B&M from a swap meet that I got several years ago. Of course it didn't have the right parts for this transmission. I ordered the parts this morning so maybe by next week We'll be back on the road. I'm glad you are a member here and were reading the "transmission section" because your's was the only answer I got. Thanks again. 454 RATTLER |
You are welcome. If you have any other questions feel free to pm or post in this thread. Have fun!
| 200r4 (automatic) with shift kit problems | 85elco | Transmission - Rearend | 7 | 01-16-2009 01:31 PM |
| 62 Impala column shift linkage ? | DADDYOOOOH | Transmission - Rearend | 3 | 03-24-2008 09:33 AM |
| Loose shift linkage? | Mertz | Suspension - Brakes - Steering | 4 | 02-06-2007 01:54 PM |
| Header collector in way of column shift linkage | Warrant | Engine | 4 | 08-29-2006 12:26 PM |
| best way to adjust shift linkage? | lemans-tom | Transmission - Rearend | 2 | 09-08-2005 02:54 AM |
