#1
200r4 shift points
We installed a rebuilt 200R4 tranny in our '59 El Camino and everything is working fine except the unit shifts just a little too early. The TV cable is adjusted correctly, all the pressures read right at the various operating conditions. I am thinking we need to adjust the weights/springs on the governor to zero in on best shift points. Anyone have any experience on doing that? I have read various recommendations from cutting off a bunch of weight on the governor weights, removing a spring from one of the weights, etc. Anyone have a formula or is it just cut and try? Our governor has the heaviest weights available, tranny was evidently from a granny car. I have seen articles on performance trannys which show governors w/ way smaller weights.
Register now (free) or login to remove ads |
#2
You best option would be to contact Chris @ CK Performance or Lonnie @ Extreme Automatics. Either could help with parts or tuning Info. It can be a pain doing trial & error with 2004R Gov, dropping Pan, draining Fluid.
What Code is the 2004R you have? Tag on right/rear. HiPer & Standard Gov ID >> http://www.gnttype.org/techarea/tra...on/governor.jpg GN/T-Type BR & BQ codes. SS-Monte CQ & CZ codes. Olds 442/HO OZ & KZ codes. All these Govs are similar, SS-Monte has highest factory Auto shift points. If you only want to raise your shift rpm/speed slightly you may only need to remove a Gov spring and change the Line Bias spring in the Valvebody etc... SS-Monte & GN Gov Pics Gove location
#3
Thanx for the reply. I have to drop the pan and change speedo gears anyway so thought I could try the first cut then. I realize it will probably require several iterations but wanted to know a good starting place. Your suggestion to remove that spring seems a good start. I have seen that recommendation a couple times.
#4
Might want to follow this thread on Chevelles
http://www.chevelles.com/forums/showthread.php?t=371666 Seems someone else is working on the same issue. If this thread hangs on for a few days---pretty sure there will be an answer. |
| Thread Tools | Search this Thread |
| Similar Threads for: "200r4 shift points" | ||||
| 200r4 shift linkage | 454 Rattler | Transmission - Rearend | 3 | 05-20-2010 06:01 PM |
| the Shift Points | Midnight Run | Transmission - Rearend | 1 | 07-31-2009 10:39 PM |
| 200r4 (automatic) with shift kit problems | 85elco | Transmission - Rearend | 7 | 01-16-2009 01:31 PM |
| 200r4 intermittent up shift to soon | 66ImpSS396 | Transmission - Rearend | 3 | 07-14-2006 08:45 AM |
| C-4 shift points | 5.0 Fury | Transmission - Rearend | 1 | 07-30-2002 11:48 AM |
