the converters are NOT interchangeable from a t-350 to a 200-4r. Did you install the 200-4r in the truck ? Or some one else? GM never built the 1/2 ton trucks with a 200-4r is why I ask. good luck
At the Bonneville Salt Flats, first gear is known as 130 mph. |
That is very interesting.
No, I did not install the 200R4 transmission in the truck. Im sure the transmission is an overdrive transmission with four forward speeds plus a lockup. There was no such thing as a 700R4 in 1984 was there?? |
If your T-350 has a 9" tailshaft housing, it's the same length as a 700R4, and your driveshaft won't need to be modified. That's the unit that came in most '73-up Chevy pickups. Most car trannys had a 6" tailshaft housing.
| 200r4 swap for a th350 | jpd37 | Transmission - Rearend | 13 | 04-16-2007 11:02 PM |
| th350 in 67 Tempest | csob | Transmission - Rearend | 1 | 02-19-2006 09:45 AM |
| Jetaway to a th350 or 200r4? | flipp121 | Transmission - Rearend | 8 | 05-14-2005 02:08 PM |
| Turbo 350 or 200R4? | Forsaken502 | Transmission - Rearend | 14 | 12-09-2003 10:11 PM |
| 200R4 VS. 4L80 VS. 700R4 Vs TH350 | WB72 | Transmission - Rearend | 16 | 11-26-2003 02:09 PM |
