Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200R4 to TH350
Thread: 200R4 to TH350
Old 10-17-2006, 10:49 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by JohnyR17
The 200R4 transmission in my '84 half ton Chevrolet pickup has died.
I will be replacing it with a TH350 not because I dislike the overdrive, but because I have a spare TH350 and Id rather not invest any money in the tired old truck.
The 200R4 has a lockup torque converter. Can I use the torque converter from the 200R4 with the TH350?
the converters are NOT interchangeable from a t-350 to a 200-4r.
Did you install the 200-4r in the truck ? Or some one else? GM never built the 1/2 ton trucks with a 200-4r is why I ask.
good luck
