200r4 trans slipping - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2010, 04:17 PM
i got a 85 monte carlo ss with a 305 in it with a thm200r4. everytime i go up a hill the car will be running at 1800 or 1900 rpms in like 2nd or 3rd gear and then all of a sudden it drops rpms down to like 900 to a 1000rpms i think its slipping into the next higher gear at too low of an rpm. what do yall think and is there anyway to fix it?
Old 08-06-2010, 09:31 PM
tnsmith10's Avatar
when will it rain???
actually with slip the rpms would go higger, not drop. all im gathering from what you posted is that the trans is able to shift while going up a hill, sounds pretty normal. the trans does have a clutch in the torque converter, but unless it comes on in 2nd which its not supposed to do, normally they dont engage while going up a hill depending on the grade or road speed of the car.
the computer has to have the right information to send signal down to the trans for it to engage the clutch in the torque converter.
i seem to notice when doing a diagnostic and seeing that the customers complaint says that the trans is slipping has ranged from the torque converter clutch not engaging, to the engine running poorly and down on power. on the other hand, there are truly times where there actual clutch plates burnt, or a band that can show that the trans was indeed slipping.
since theres not much a code scan can do for this particular car based on the year of it, the best suggestion would be to take the car to a well reputed transmission shop that has a good driveability technician who can tell the difference on whether you have an actual trans problem or possibly its and engine related issue.
on a side note, have you checked the fluid to see if maybe its low and took a sniff on whether or not its possibly burnt?
Old 08-07-2010, 03:52 AM
yea i changed the fluid and the filter it didnt smell like it was burnt and the fliter was just old. there was no metal shaving in the pan either... and also too when i go to pass a car and get on it. it does the same and drops in rpms but still slowly picks up speed
Slipping TH350 trans dirthead Transmission - Rearend 3 12-28-2009 07:20 AM
4L60e slipping in 2-4 elwrencho Transmission - Rearend 7 12-01-2009 07:09 PM
Ideas for "MY" Trans AM 3rdGenFreak Hotrodding Basics 0 12-10-2006 02:09 AM
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-11-2006 11:24 PM
Corvette Trans T-400 or 200r4, johnnybegood Transmission - Rearend 9 10-22-2002 06:29 PM
