Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 200R4 TV cable
Thread: 200R4 TV cable
Old 09-20-2008, 06:39 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
You do not want to force the cable adjustment by using the throttle to pull the TV cable out...this can bend the internal TV link and linkage on the valve body.
IF there is slack in the TV cable on this 200-4r trans,you need to correct the geometry and the inner cable length
