200r4 tv cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 08:37 AM
200r4 tv cable
i need help adjusting the tv cable on my trans, i pushed the adjuster tab then moved it back to the fire wall, open the throttle, but the adjuster wont ratchet to adjust, its a brand new cable. any thoughts?
Old 03-22-2005, 08:49 AM
Check the carb to ensure that the accel pedal inkage pulls the carb to wide open. If this is true, check for bracket flex at WOT. With carb at WOT, the cable is pulled taught. Check this by checking tension on the cable itself, where it passes thru the carb attachment end. If you cannot pull the cable forward at WOT, it is tight.
700R4 TV cable on a 2x4 Tunnel Ram ??? BinderRod1939 Transmission - Rearend 3 08-24-2004 05:52 AM
Any hints on setting a TV cable for a trans? Oreif Transmission - Rearend 3 11-14-2003 09:30 AM
TV cable issues on 200r4 Roy_67_SS350 Transmission - Rearend 2 09-16-2003 12:55 AM
TV Cable MI2600 Transmission - Rearend 2 09-05-2003 07:26 PM
700r4 TV CABLE installation or calibration ss crazy Transmission - Rearend 2 04-07-2003 09:20 AM
