200R4 won't downshift normally - Engine lugs to a stall
Ok, I've installed a rebuilt transmission in my '63 Nova. I installed the TCI lockup kit that sends 12v to the trans and the ground is switched via a vacuum switch.
On my test drives, I've found it has an issue. It shifts up through the gears just fine, but doesn't shift back down at zero throttle and the engine lugs to a stall as if I were in a manual tranny car and I was braking to a stop with the car in gear. I have tried: disconnecting the power to the transmission, disconnecting the vacuum to the TCI vacuum switch, moving the vacuum from manifold vacuum to carb vacuum, and jumping the ground wire to make sure I was getting good ground. The symptoms seem to remain exactly the same no matter what I do. From my research here and a couple other sites, I am thinking I have a sticking 4 gear lockup solenoid. Problem with that theory is that it's brand new. Finally, I have a 4:10 diff and I haven't switched the speedo gears out yet, so it reads about 20 mph too fast at 50 mph. Could it be that the speedo gears have something to do with it? That is, could the trans be thinking it's going to fast to downshift? Any help/opinions would be great. I am lost. Also, a definite answer about the speedo gears would help my direction. Thanks in advance. |
Even if the TCC Solenoid is new it may be sticking=bad. Or Converter Clutch Valve sticking/binding, it's in the bottom of pump also.
http://www.makcotransmissionparts.co...Rsolenoid.html Here's a good Speedo gear calculator, just input your Info. > http://www.montess.org/speedo_gears.html Gears http://www.ckperformance.com/resourc...ellaneous.html |
I've got a TCI 2004r in my monte and I had a problem after 1st installing it as it would stay locked up and stall the engine when I came to a stop. It has a hydraulic switch wired into the 4th gear test port that locks up the converter when it gets into 4th. I had to wire it in series with my brake light switch to get it to work correctly. You can wire a manual switch in parallel with the 4th gear switch if you want to lock it up in other gears, but you will still need to wire that through the brake switch to make it un-lock.IMHO
ssmonty |
I'll give it a try. Thanks for the input.
If I can avoid dropping the pan and the mess that ensues, I'll be a happy guy. |
Here's an update:
I wired in an interrupting circuit using a relay that kills the power to the trans when I apply the brakes. That is, when the brake light switch is closed, the power circuit to the trans is open. It worked, and I was encouraged, but then after a couple of miles, it started back into the same old symptoms. I called the tech line at the trans shop and they agreed that it must be a sticky TCC solenoid. They are sending one out today and I will be changing it out. I believe this will fix it. I do find it odd that the problem seems to start as the engine warms up. But I believe the new TCC solenoid will fix it. |
| acceleration flat spot in carb. | corvettetonybone | Engine | 17 | 04-13-2013 08:31 PM |
| crate chevy 302? | Vancouver Grand Prix | Hotrodders' Lounge | 106 | 12-31-2012 04:05 PM |
| Build for Hp or Torque? | Venturat | Engine | 76 | 09-23-2008 10:22 AM |
| engine temp now hotter with 3800 stall | black66 | Engine | 3 | 05-14-2006 01:42 PM |
| stall converter | adam15425 | Engine | 26 | 10-15-2004 05:50 PM |
