-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   2011 5.0L Mustang Engine Question?? (http://www.hotrodders.com/forum/2011-5-0l-mustang-engine-question-212084.html)
waltrobak 01-09-2012 07:13 AM
Does anyone know if the new 5.0L Mustang engines have the same bell housing bolt pattern as the older 5.0L engines from the "80's"?? I have a C6 Tranny that I would like to bolt up to this engine and I was wondering if it will work without any special adaptors. Thanks
Siggy_Freud 01-10-2012 05:28 PM
Not sure to be honest. Might ask over at the Mustang Forums (google it) as they have a sub-forum dedicated specifically to the 5.0.
To be honest, I would doubt if it's a direct bolt-in.
matt167 01-10-2012 06:24 PM
The bellhousing is not the same. The new 5.0L in the Mustangs is a modified Modular motor. Essentially the Factory copied stroker kits for the 4.6L which have been out for a few years and added some new heads to make the new 5.0L.. C6 was never common in a SBF bell pattern ither, and the big bell pattern went away with the 460 after 1997
