2011 5.0L Mustang Engine Question?? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 01-09-2012, 07:13 AM
Does anyone know if the new 5.0L Mustang engines have the same bell housing bolt pattern as the older 5.0L engines from the "80's"?? I have a C6 Tranny that I would like to bolt up to this engine and I was wondering if it will work without any special adaptors. Thanks
Old 01-10-2012, 05:28 PM
Siggy_Freud's Avatar
Not sure to be honest. Might ask over at the Mustang Forums (google it) as they have a sub-forum dedicated specifically to the 5.0.
To be honest, I would doubt if it's a direct bolt-in.
Bringing history and technology together.
Old 01-10-2012, 06:24 PM
Wiki Edits: 31
The bellhousing is not the same. The new 5.0L in the Mustangs is a modified Modular motor. Essentially the Factory copied stroker kits for the 4.6L which have been out for a few years and added some new heads to make the new 5.0L.. C6 was never common in a SBF bell pattern ither, and the big bell pattern went away with the 460 after 1997
Recent Modern Electronic Engines posts with photos
2011 Chevy Silverado silverado owner Hotrodding Basics 1 12-29-2011 10:28 AM
First Cruse-In 2011 trees Hotrodders' Lounge 0 04-24-2011 07:12 AM
2011 ************** Tour familyevents Hotrodders' Lounge 1 03-23-2011 10:59 AM
Ford to reveal 2011 Mustang powertrain popei.oliver Hotrodders' Lounge 3 10-13-2009 03:04 PM
