Thread Tools Search this Thread share on Facebook
  #1
Old 12-29-2008, 09:03 PM
jarice1978 jarice1978 is offline
202 heads, no assecory hole...what to do?
Hello,
I have been working on a 1970 chevelle for over 2 years now. We are currently assembling the motor that has been set in the car with nothing on the front (fenders, core support, inner fenders...)
We purchased a rebuilt 350 modified to a 383.
We were given 202 heads with the motor and are using those.
Just installed new edelbrock intake and carb so I really don't want to take all of that back off...
Then as we were attempting to hookup the alternator we said "Hey! There is no hole!"
Didn't realize it before. What should we do about this? Is there another easy way to mount the alternator and power steering (no a/c)? Are there some brackets I can buy that are specifically made for this? I would hate to have to make some...
If you need some pics let me know and I will post some...
Thanks,
Joe
Register now (free) or login to remove ads
Old 12-29-2008, 10:10 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
http://www.alangrovecomponents.com/
They have the brackets you need.
Old 12-30-2008, 05:57 AM
65smallblock 65smallblock is offline
If you can get brackets to make it work that would be best. Most folks will tell you that you cant drill the holes because the heads will break and in most cases they are right. But I had a 71 blazer with that situation and made it work. The trick is to make spacers that are contoured to the shape of the head and to be absoloutly certian that you are in no way placing a bind on the head. It has to be very secure and carefully done, but it can be done.
Old 12-30-2008, 09:37 AM
454C10 454C10 is offline
I have drilled and tapped holes in my old fuelie heads with out any problems.
and I have also used an aftermarket bracket that only bolted to the water pump.
both worked equally well.
drilling and tapping a hole is cheaper. and you will need to use rtv on the threads that go into the head. drill a "straight" 5/16 inch hole and use a 3/8-16 tap (high speed tool steel, not a carbon tap). coat the tap with grease to catch the metal chips.
Old 12-30-2008, 10:37 AM
junior stocker's Avatar
junior stocker junior stocker is offline
early heads-no accessory holes.
My 82' truck has had several engines in it over the years. At one time it even had a 340 H.P. 327 in it. That motor had "fuelie heads", without accessory holes; I used the trucks stock bracketry, and fabbed up some "connecting" brackets with straight stock. Worked fine, looked hokey, did'nt cost anything except my time. But, quite frankly, it looked a whole lot better than those Alan Grove high mount brackets.
Old 12-30-2008, 12:25 PM
machine shop tom machine shop tom is offline
Ya don't need to do anything. Just use a bolt and nut instead of the long bolt and spacer (that goes to the head).
I've been doing it that way for 20+ years with no problems.
tom
Old 12-30-2008, 01:42 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I got those brackets you need, check your PM. The little bracket bolts to the bolts that hold the water pump to the block. The big bracket bolts on to 2 bolts bosses on that pump. The alternator goes in between the 2 brackets. Nice and clean and no holes to drill.
Old 12-30-2008, 02:31 PM
Thanks for the info. I am probably going get some brackets. I did check out the alan grove website and some of those high brackets are out of control. And paying $90 for a 5" x 5" piece of metal makes me nautious! But at least I can complain to someone else if it doesn't fit.
I also need a bracket for the power steering pump.
Thanks,
Joe
Old 12-30-2008, 04:20 PM
RPM's Avatar
RPM RPM is offline
those are alan grove brackets. I have the one for the ps also. check your pm.
Old 12-30-2008, 04:33 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
tom
Yep....have done it many times. Once the other brackets are tightened up, it's fine.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 12-30-2008, 05:54 PM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
I have built brackets with a drill, a chopsaw, some 1" wide flat stock and a welder.
Basically I built a strap that goes behind the alternator, It was mounted to the intake at the top and either the header bolts or the front bolt holes on the bottom of the front of the motor. You can just drill a hole or put a 3/8 tap in the strap and run a bolt into it You can even mock up the rest of the brackets and install the alternator and use it as a template so you know where to drill the hole.
Same thing with the Power steering pump bracket. It cost around 10 bucks in steel and around 4 hours to do the whole thing. If you do it right it looks stock.
Old 12-31-2008, 06:30 PM
Jim Rockford's Avatar
Jim Rockford Jim Rockford is offline
World Famous VF-14
Last journal entry: new 77 impala coupe
sell those crappy heads and get some that make power...
Old 12-31-2008, 07:02 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Here we go again!
Old 12-31-2008, 08:30 PM
SeriousPower SeriousPower is offline
Originally Posted by jarice1978
Hello,
Thanks,
Joe
I am experiencing the same problem with the engine that I am building, but it is by design. My heads are a set of Double Humps that came off of a early 70's Vette with the 1.94 valves. What I am doing is using an alternators that is mounted on the bottom from the water pump. I purchased my set from Summit at a real reasonable price. If you are using a long style pump then use the brackets for the long pump and so on. Easy fix. A lot easier than going through the worries if your going to ruin your heads or not.
Old 01-01-2009, 08:52 PM
bigzeke bigzeke is offline
no holes
machine shop tom is right ,simply use a nut and a long bolt , i have those same heads and i drilled a complete hole through alt and installed a nut and bolt , im also running a serp belt set up from a 87 chevy caprice and i havent had the first problem , good luck ,birdman92
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "202 heads, no assecory hole...what to do?"
ThreadThread StarterForumRepliesLast Post
HiPo headsRJLEngine1606-29-2009 09:18 PM
getting old iron heads to flow? (SBC)KNanthrupEngine912-21-2005 05:06 PM
FE blocksSAATREngine2703-14-2005 04:35 PM
Wut set of heads for my set up?TravEngine210-15-2003 09:45 PM
sbc headsJaredEngine703-03-2003 07:07 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
