205 tranfer case - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2011, 04:46 PM
205 tranfer case
i have a 205 transfer case there was a turbo 350 27 spline on it is there a adapter to change the tranfer case to a 32 spline for a turbo 400
Old 10-08-2011, 05:01 PM
Try (advance adapters) or( jb conversion )
Old 10-08-2011, 05:04 PM
Thankyou i will
Old 10-09-2011, 04:50 PM
I have read that you can just swap the output shaft, but I'm not sure how hard it will be to do the job. This place sells the replacement shaft you need.
http://offroaddesign.com/catalog/transfercaseparts.htm
They also sell adapters, but I'm not sure if they replace the factory adapter, or add to it. If the adapter is longer it would move the Tcase back several inches. This would mean changing the length of both driveshafts.
Bruce
Tranfer Case Swap NP1 to NP8 ucblack2 Transmission - Rearend 0 03-04-2009 09:41 PM
th 250 case, same as 350 Icelander Transmission - Rearend 10 02-03-2009 10:26 PM
t-case capn_crunch4x4 Transmission - Rearend 2 06-02-2006 02:54 PM
T10 Case or SuperT10 case?? GMBrutus Transmission - Rearend 1 02-16-2004 02:37 PM
