20w50 or 10w30? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2007, 10:58 AM
84Z 84Z is offline
Gas Raper
20w50 or 10w30?
I have a 408 engine producing about 500 to the flywheel, and 200 shot on top of that (only at the track) running 93 octane, engine temp chills at 190ish, engine is not filled with cement. Right now for break in I have 20w50 synthetic (which was put in by my mechanic), should I switch to 10w30 or keep the 20w50? I also have a roller hydraulic cam, high volume oil pump, and true roller rockers.
Old 04-16-2007, 12:03 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Viscosity of oil is more determined by ambient temps and internal tolerances at the bearings. Power levels have little to do with it. If you have the right oil in the right clearance, thickening it won't add protection, it will just make it harder for the oil to get there to protect.
Unless you went with really loose tolerances, 10w30.
Old 04-16-2007, 12:33 PM
10w30....if the clearance is right in the motor, you should have no problems. might even free up a couple of hp
Old 04-16-2007, 04:44 PM
Berliner Bel Air's Avatar
Beyond the Sea
synthetic is too slippery for break-in. Use mineral oil at least for the rest of the break-in.
Old 04-16-2007, 05:46 PM
curtis73's Avatar
Wiki Edits: 16
He has a full-roller valvetrain, so synthetic isn't a problem.
30wt v.s 20W50 runn141 Engine 17 12-14-2006 03:07 PM
10w30 fo blood greg ingram Introduce Yourself 2 02-22-2006 12:28 AM
synthetic oils Hoyt Engine 24 04-05-2004 02:26 PM
