211W155 threading instructions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2008, 10:40 PM
Elleka's Avatar
Last journal entry: Old interior
Does anyone have a clear pic of a 211W155 threading instructions, or their own machine . . . threaded (close up)? The on-line diagrams aren't very clear. Thanks.
Old 11-02-2008, 08:42 AM
DanTwoLakes's Avatar
Wiki Edits: 22
This is not a Singer 211W155, but is threaded the same way through the same type of tension. I used bright yellow thread so you could see it better.
ID:	33853   Click image for larger version
Old 11-02-2008, 04:01 PM
Elleka's Avatar
Ty
Hi Dan. I knew I could count on you after reading some of the interior posts. Thanks so much. I was up till 1am last night going thru your bench seat tutorial. It will be so helpful when I start my project. I'm still getting used to this machine. It is soooooo much different than my home machine. I asked the shop to put in a 3000 Reliable Servo motor, but they put in a Consew instead. Think I should ask them to put in the Reliable, as I requested? Also, with the adjustable speed turned down all the way, I'm still getting "speed" if I press down on the treadle hard. Is this normal? Thanks again for all your help here. You are so appreciated.
Old 11-03-2008, 07:10 AM
Wiki Edits: 22
I'm not real familiar with other types of servo motor, but it will give you whatever top speed it is set at.
My motor I can set it so that full speed does one stitch at a time, very slowly. If that appeals to you, then yes, I would ask them to put on the Reliable sew-quiet 3000 that you asked for in the first place.
Old 11-10-2008, 03:41 PM
For future reference, there is a downloadable service manual for the 211W155 at:
http://parts.singerco.com/IPsvcManuals/211W155.pdf
Many of the pictures are fuzzy, but the threading diagram is quite clear.
Ed
http://sewing-machines.blogspot.com
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
anyone have pertronix install instructions & tech help? dbuff Engine 3 10-18-2004 10:39 AM
items on manufactures instructions crshrmn3 Hotrodders' Lounge 5 12-28-2002 01:01 PM
hidden hinge instructions bugsoup Body - Exterior 3 08-14-2002 03:24 AM
