220 to 110 volt air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2007, 06:25 PM
Hi Guys,
Need some help. I have an air compressor that is run on 220. I need to convert it to 110 volt. Can I just change the cord?Thanks in advance.
Thom
Old 10-19-2007, 06:46 PM
More than likely you will need to change the motor. Some motors can be hooked up for 110 or 220 operation depending upon how you connect the motor leads. Check on the side of the existing motor. There should be a nameplate that will indicate whether it is a dual voltage motor or not.
Old 10-20-2007, 06:12 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
It will use less electricity and run better on 220.
Old 10-23-2007, 06:10 AM
Not true, it'll use the exact same amout of electricity and perform the same as long as everything is sized correctly. You're paying by KW's not amperage or voltage. The andvantage to 240 volt vs 120 volt is that the amperage is 1/2, which means you can use a smaller gauge of wire to do the same work and being what the price of copper is these days, that can be a significant amount of savings!
Old 10-23-2007, 05:15 PM
Whether or not it can be converted to run on 110v also has to do with how big of a motor it is. My 5 hp motor is plated 22-25 amps at 220v & I have measured it at 19-19.5 amps with a clamp meter. This compressor would use 38-39 amps at 110v to run & the startup current would be 90 amps.
Old 10-24-2007, 03:59 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Most UL-rated electrical components have wiring diagrams on them somewhere. If you pull the electrical box apart there should be wiring diagrams for both voltages. If not, go online and find the wiring for it. It doesn't matter if its the same exact model or not, its all wired the same for any of the dual-voltage motors.
Old 10-25-2007, 05:32 AM
Actually, FLA (Full Load Amps) on a 5 hp, 120v motor would be about 56 amps and starting current, which is basically the same as LRA (Locked Rotor Amps) is about 336 amps.
choosing a compressor oldred Garage - Tools 12 03-14-2012 09:40 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
$88.88 air compressor baddbob Body - Exterior 1 02-08-2006 08:28 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Hopping up an air compressor?? LanceM Garage - Tools 5 02-18-2005 07:40 PM
