220 or 230 amp MIG welders - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2009, 07:45 PM
chase1994's Avatar
For a welder that uses 220 or 230 amps would it still be a good one for sheet metal?? The welder I have in mind is the Millermatic 180 with autoset. How good of a welder is this for sheet metal repair and stuff like that. Thanks
Old 07-10-2009, 07:56 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
I am assuming you mean 220 Volt. The Millermatic with auto-set is a great choice. I recommend going over to Millers website and read up on it because it does have some limitations. I believe that Miller comes with the MVP plug so it can run on 120 or 240 just by changing the plug end. You won't be disappointed with blue.
Old 07-10-2009, 08:19 PM
How good is it? A heck of a lot of welders, most probably, would say it is the best in it's class. Although personally I am more inclined toward Lincoln the fact is if you are considering a welder of that type you simply can't go wrong with Miller!
Old 07-10-2009, 08:23 PM
chase1994's Avatar
oops my mistake ya i meant voltage. OK thanks guys, I have read on it a pretty good bit. I was thinking about the millermatic 140 at one point then I saw this one and was thinking it would be a better choice.
Old 07-10-2009, 08:36 PM
302 Z28's Avatar
Go with the 220 volt model, it gives you a lot more flexibility over the 120 volt model IMHO.
Vince
Old 07-10-2009, 08:57 PM
my mistake its the 211 that has the 220/120V option. sorry.
Old 07-10-2009, 09:28 PM
life is a temporary assignment
Vince
Vince is 100% right about this...Don't settle for anything less..
Old 07-11-2009, 09:36 PM
chase1994's Avatar
thanks guys. I will go with it.
MIG Welders EmmaRose Garage - Tools 16 03-13-2009 09:54 PM
Hey mig welders... Slickriffs Body - Exterior 3 08-16-2004 05:27 AM
90 amp mig enough? drewcoolness99 General Rodding Tech 1 11-19-2003 02:22 PM
Low end mig welders? Slickriffs Body - Exterior 19 08-05-2003 06:19 PM
