Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 220 V issue
Thread: 220 V issue
Old 10-31-2009, 10:28 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
If you try and run a 30 amp rated device from a 20 amp plug you will have problems. Your compressor has a 20 amp plug. It does not draw 20 amps, there is a safety margin built into the plug size and wire size. Also the plug configuration excludes you plugging that 20 amp plug into a 30 amp receptacle. The circuit breaker is there to protect the wire, not the device at the end of the wire.
Vince
