I am not an electrician, however, you can run a 20 amp compressor on a 30 amp circuit without a problem. Circuits are designed with the appropriate breaker to protect the wiring and not the equipment on it. The compressor will run well on the dryer circuit.
Thanks for the info. I noticed they sell the plug and wire in 6 foot length specific for dryers. I could buy additional 10 gauge 220 wire and make an extension cord to my air compressor. I figure the cost with wiring and a plug will be about $60 which is better than $500. It'll be nice to be able to use my air tools again as well.
Ed I'm confused now, I got this from an old post in here. The guy is a licensed electrician and quotes," It is a dangerous practice to run a plug on a circuit that it's not intended for such as putting a 30 amp drier plug on a 20 amp piece of equipment. This is a violation. You must use the correct plug for the circuit and not go over or under. I'm a licensed electrician by trade.[/QUOTE] Last edited by kleen56; 10-31-2009 at 09:52 AM. |
If you try and run a 30 amp rated device from a 20 amp plug you will have problems. Your compressor has a 20 amp plug. It does not draw 20 amps, there is a safety margin built into the plug size and wire size. Also the plug configuration excludes you plugging that 20 amp plug into a 30 amp receptacle. The circuit breaker is there to protect the wire, not the device at the end of the wire.
Vince |
I think that quote is from a thread I was involved in last year. I spliced in a standard dryer cord to a 10 gage line I ran into the garage for a welder (20A). The dryer line is on a 30A breaker meaning that the welder (or anything else not rated at 30A on that line) may not be protected. But, this is the same as probably every appliance or power tool you plug into a 120v outlet so to me it's a moot point. In my case, the 10gage line ends in a 20A plug but wire size is correct for the 30A breaker. I got some crap for this setup but I maintain that as long as the wire size is correct for the breaker and workmanship is correct it is safe. I included pictures of my set-up in that post. |
[/QUOTE=scotzz]I think that quote is from a thread I was involved in last year. I spliced in a standard dryer cord to a 10 gage line I ran into the garage for a welder (20A). The dryer line is on a 30A breaker meaning that the welder (or anything else not rated at 30A on that line) may not be protected. But, this is the same as probably every appliance or power tool you plug into a 120v outlet so to me it's a moot point. In my case, the 10gage line ends in a 20A plug but wire size is correct for the 30A breaker. I got some crap for this setup but I maintain that as long as the wire size is correct for the breaker and workmanship is correct it is safe. I included pictures of my set-up in that post.[/QUOTE]
Again, the circuit breaker or fuse is not to protect the welder or anything else that is hooked up to the wire. The breaker or fuse protects the wire. That is why a circuit is first sized for the anticipated load. Then the circuit breaker is selected as is the proper wire size for the anticipated load. Wire size is selected at 125% of max load. Vince |
Your compressor has a trip breaker installed as federally required by law for the appropriate amperage. Connecting it to service line with the higher amperage as discussed will not violate any laws as it will will still function as it was designed without overloading the circuit.
Hopefully you did a good job in splicing the extension wiring. I don't think that ou can have any kind of a permanent installation where both ends plug in. So, it would be like an extension cord.
I also don't know about what a good splice would be. I would imagine that properly sized wire nuts (Scothchlocks or equivalent) would work. To be really safe, you could make the connections inside of a metal electrical box and make sure that you ground the box. I'm not familiar with 220v dryer plugs, but newer designs should include a ground wire. You can put a plain metal cover on the box. You should also use strain reliefs on both ends. I have fixed more than one extension cord with wire nuts and electrical tape, but you have some heavy duty stuff here. It would be easier to get 10 ga UF 3 wire plus ground cable to make the extension. Otherwise you have to keep the wires together somehow. Depending on how your house is laid out, it might not be that difficult to just run a circuit from your fuse box. If you can use flexible cable rather than conduit, it could be fairly straight forward. You can find electrical code books at the library. |
| Recent Garage - Tools posts with photos |
| Strange overheating/Idle issue. | JoBlo | Engine | 8 | 10-22-2009 06:31 PM |
| Heater switch issue..? | el pollo | Electrical | 3 | 11-02-2008 07:13 PM |
| Wiring a 220 off an existing dryer outlet 220 | bstage | Electrical | 6 | 08-25-2008 07:47 PM |
| 10-12 Bolt U-joint Issue Issue | MrB | Transmission - Rearend | 3 | 09-29-2007 08:17 AM |
| 220 vrs 110 compressor for paint | Slickriffs | Body - Exterior | 7 | 07-11-2007 04:31 PM |
