I needed a 220 outlet in my garage to run a welder. I called around and most people wanted in the 400 dollar range to run a 220 line from the electrical panel about 15 feet away. I finally found a guy (professional licensed electrician, not a handyman) that was willing to do it for a bit over 200. I opted to have a second outlet put in for a few bucks more. So your estimate is on par with most of the estimates I got, but still too much I think, especially if you are providing supplies. I'd keep calling around you might get it cheaper. It's a tough job market out there and I know electrician who can't find much work. I'd let them know what you want to pay and you might get a bite. It only took about a couple of hours and that included a run to Home Depot.
I've done enough of this to know all jobs aren't created equally. Is your service box easily accessible, or is there some cutting involved, stucco, siding, sheet rock, etc? Is the wire going into conduit? Is it indoors or out? Is it a straight shot to the outlet or involve a lot of bends? if it were to be done in an unfinished garage, no obstacles, straight run, about $100. Throw in the obstacles and you're adding time. A good electrician will figure about $100 an hour for his labor. A good do-it-yourself-handyman will probably get $25-$50 an hour. Check out the thrifty nickel kind of newspapers. and like Heyjude says, can you make all this work with your present box? It's not a terribly difficult job for a handy kind of guy, I'd say around $200 max should get the job done, labor.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
| Recent Garage - Tools posts with photos |
| Brake Line Flare Nut advice needed......... | scotzz | Suspension - Brakes - Steering | 13 | 01-20-2009 04:43 AM |
| Could It be my Fuel Tank / Fuel Line? | 10mikeymike | Engine | 4 | 09-17-2008 02:25 PM |
| fuel line advice needed | mike bryan | Engine | 4 | 12-04-2004 09:14 AM |
| Body Line | Man586 | Body - Exterior | 6 | 08-20-2004 08:24 AM |
| Is line honing needed to prep block? | dpjmw | Engine | 2 | 08-19-2004 07:04 AM |
