Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 220v mig welder extension cord?
  #21 (permalink)
Old 10-06-2003, 07:53 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
It is common NEC (National Electrical Code) practice to protect #10 AWG wire with a 30 amp fuse or breaker, #12 is 20 amp, #14 is 15 amp. These figures can vary slightly depending on the wire type and installation., but as a general rule these figures are good
It is also standard engineering practice to size wire at 125% of full load. At 19.5 amps with 4/C #10, you are way under the max load....start welding.
Vince
