220V welder or 110V
I have been pricing welders I can get a hobart 180 220V for 699$ CDN or a millermatic 135 for $749 CDN
It sounds like a no brainer, but to run the hobart, I have to get a proper 220V subpanel feed into grandmas garage. This is going to probably cost me $200 to $300, plus a day and a half labour to dig a decent ditch to run the wire through from her house to the garage (40 feet and a tunnel under the sidewalk) |
Yes,That 120V will do most anything you need. Also more "portable" for when your friends,"Oh you got a welder?",need something done.
Only deal is when using it on it's higher settings,You WILL need a GOOD #10 ga wire cord and circuit as it does pull some juice and can trip a simple house recpticle circuit. The 220v loop for the shop is comming anyway you know, Welder,air compressor,A/C,tanning bed,2000 watt surround sound,105" TV, the list goes on and on.
The 110 welder would probably do most of what you need it for, but in my opinion, a garage without 220 is... just not right, dangit! If you want to get serious, 220 volt equipment is the only way to go, especially air compressors that can paint a complete or run a large air grinder without wild swings in pressure. So ask yourself how long you will be doing work there, how much work you will do there, and decide if the investment is worth it. Most homes actually do have 220 at the panel, so a subpanel may not be necessary if there is space in the panel for another breaker.
Be there for a while???
I woudl certainly do a 220 circuit out to the garage..actually 2 seperate questions to me..I own a 110 Linclon wire feeder and it has worked fine for me for a long time..but then you do need a good solid power source so I would dig the trench and lay a 220 circuit in..You will be glad you did down the road..
OMT
I personally believe that any garagem, large or small, will eventually need 220V out there. That is something that you can do when ever though. The 110 unit will serve you good, as ling as you don;t have some really thick stuff to weld. As was said, you will need a really heavy extension cord for it. A smaller cord will reduce the power of the welder and likely trip breakers.
I have a 110 and have used it to weld up the frame and motor mounts on my car. It does the job but you wont get hours of continuous weld time. I can weld about 3 - 4 4inch welds and it will shut down. That is on the highest setting.
It got the job done but if I had the choice and money was no object I would get the 220. |
Thanks guys, it's not my garage, so If I wire it for 220V, it is an extra expense that I am going to have to consider carefully.
The tool shop set up a welder and I tried out a Miller 135 today. I am going to go back some time this week, and try the 220V hobart as well |
| Mastercraft Mig welder? Canadians eh | montea | Garage - Tools | 19 | 01-23-2007 11:24 AM |
| is this welder any good?? | michiganjoe | Body - Exterior | 10 | 11-23-2006 07:57 AM |
| Hobart Champion 4500 welder | sotxpanrider | Garage - Tools | 2 | 03-06-2005 09:07 AM |
| 220v mig welder extension cord? | fatherandson53 | Garage - Tools | 36 | 01-18-2004 10:51 AM |
| Arc welder ~VS~ Mig Welder | ChrisMiddleron | Electrical | 15 | 07-08-2003 07:31 AM |
