-   -   225 slant 6, w/trans ? (http://www.hotrodders.com/forum/225-slant-6-w-trans-226169.html)
39chevy 11-16-2012 05:07 PM
What problem will I have if any to use the 907 trans ( I think this is the right #) to get a drive shaft to hook from there to a 12 bolt 1/2 ton gm pick-up? Also is there a cross member to accomodate my motor mts etc? I don't want to find out later after the fact, don't need no surprises, advise, thanks, Dana
vinniekq2 11-16-2012 05:29 PM
any shop that cuts drive shafts can fix you up. rear trans mount will be easy to fab,not sure about engine mount
