23 t 4 wheel disk brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2005, 03:18 PM
I am installing a set of polished baer brakes "Rod & Drag" units in the back on my small ford 9 inch.
This system utilizes PBR lightweight single-piston calipers with an integral park brake mechanism. The rotors dimensions are 11.35" x .810" and are directionally ventilated rotors.
On the front I am using Wilwoods polished Forged Billet Dynalite 4 Piston Calipers and spindle mount kit.
I am using a corvair steering box and doing the vertical steering column thing. The trany is a polished aluminum powerglide.
at this time I have a single reservoir master cylinder like on a 66 Impala and it just fits between the shifter arm on the trany and the bracket for the steering box.less than 1/4 inch clearance front or back. and can not use a longer push rod to mount master cylinder behind the steering box.
I would like to use a swing pedal system and mount my master cylinder on the firewall. I have no options I can see and still run a dual reservoir master cylinder. I have thought about using my single master cylinder to activate a remote system but have decided that a remote system is only as safe as its weakest link and with everything in place on a remote system you still really only have a single reservoir brake system. If anyone has a great idea please contact me on this subject.
I would also like some info on a good place to purchase my brake lines. and what would be the best size. I know I want stainless steel. thanks
[IMG]
ID:	8784   Click image for larger version
Old 12-31-2005, 03:36 PM
302 Z28's Avatar
There are systems that mount a dual master cylinder totally under the dash. For brakes lines and hardware try these people. I didn't totally understand why you could not use a longer pushrod and mount the master cylinder further back under the body
http://www.performanceplumbing.com/
Vince
Old 12-31-2005, 03:56 PM
the steering box and trans crossmember take up all the room that would be needed to install a rod. It's like a five car crash in that area! thanks for the info
Old 01-01-2006, 04:14 PM
302 Z28's Avatar
Forgot to mention brake line size, 3/16" is most common. Really no need to go any bigger. 3/16" is an uncommon size for any local supplier. Industrial instrument repair and construction firms will have 1/4", 3/8", and 1/2". At work we have an instrument vendor who comes in occasionally and I had him order two 10 foot stalks of 3/16" SS tubing for me. he charged me $2.00 a foot which is far below what I could have ordered it for any place else.
Vince
Old 01-02-2006, 09:08 AM
T buckets rule
On my buckets the master cylinder is under the floor behind the trans crossmember. I just made a very long rod from the under floor pedal to the master. I used a master from a 76 Vega. They work fine.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
67 chevy truck disk brakes ,HOW? oklowride Suspension - Brakes - Steering 4 11-15-2005 11:53 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
Parking Brakes and rear wheel self adjusters jpd37 Suspension - Brakes - Steering 2 02-28-2004 11:10 PM
Disk Brakes for 3/4 ton 1966 Chevy P.U. big_daddy6464 Suspension - Brakes - Steering 4 10-21-2003 03:12 PM
