235 6cyl 1960 pick up manual trans questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2011, 11:37 AM
I would like to use a different std tranny on a 235 6cyl 1960 pick up.it now has a granny 4spd. want to keep it a floor shift. any suggestions,please?
Old 04-01-2011, 12:59 PM
What are you trying to accomplish?
Old 04-01-2011, 01:46 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
You could look for a 3speed W/OD or a Saginaw 4 speed.(no granny)
Floor shifter required for the 4 speed(in that vehicle) As for the three speed, Hurst has floor shifters for them. Hurst called them mystery shifters. As it was surely a mystery as to weather you'd get the next gear or not. (the nut at the bottom of the shifter would get loose & you'd loose that race)
Rich
Old 04-01-2011, 02:55 PM
Indy shifter (made by 'hurst' now B&M) for your 3spd
Change to a different ratio 3spd
Convert to a 5spd T5 trans
Muncie/T10/Saginaw 4spd
Old 04-01-2011, 03:06 PM
tranny
I do not like the granny 4sp,and I will not be towing a trailer.looking for good milage at highway speeds,and not have a very low 1st gear like the granny.
Old 04-01-2011, 03:12 PM
Look for a trans with a 1st gear in something like a 2.98, 2.88 or 2.64 and a rear axle of around 3.23:1. This is assuming NO overdrive
Lowering a 1960 Ford Pick up rushlow Suspension - Brakes - Steering 2 11-14-2011 11:27 PM
replacing the side windows on a 1960 pick up crusin60s Body - Exterior 2 03-29-2011 01:15 PM
Trans swap questions, manual to automatic melton24 Transmission - Rearend 1 10-27-2010 05:12 PM
1960-64 corvair 110, is it manual or auto ? fast68 Transmission - Rearend 4 11-06-2009 08:04 AM
questions for a auto to manual trans swap johnnyt5646 Transmission - Rearend 0 02-05-2009 01:52 PM
