235 chevy dual carbs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2008, 08:19 PM
grafter's Avatar
I have dual 1bbl rochesters on a 56 inline chev 235. it ran great with one carb but two seems to be too rich for her. I am wondering if anyone has had experience building a progressive linkage for this set up or if one is sold? so far all I have found is the single linkage rod connecting both carbs and opening them both at the same rate.
Old 01-30-2008, 09:32 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Some say you can't run 2x1 or 2x2 on a 6 OR a v-8 using progressive, but there are people out there that claim theirs has worked fine.
A switch to 2-ones should not make it richer. Each carb is open less at a certain rpm, than if one carb was used.
Even the little Corvair 6 had FOUR 1 barrels as an option.
Sounds like there is something wrong with one or both carbs.
I'd try running it on one; and if it runs OK on the road, then unhook that one and try running on just the other one. Hopefully one will show a problem. And if it does run Ok one one,maybe it will survive on a progressive linkage.
Some thread I read just this week about inliners w/ 2x1. I think they said it would not run great until it got fully warm because their intake did not have the factory exhaust-heated abilities. So, during warm up, the manifold ices and that definately causes richness & poor running/idling.
Old 01-30-2008, 09:47 PM
grafter's Avatar
I have swapped out several carbs.. finally got some n.o.s. ones that run pretty well. I think youre right about the heat problem. there was an old fenton intake on ebay that had a pipe through it. it was water heated. now I know why. it went for too much $$ for me. it may run better when the weather warms up. I was just curious about the linkage, I like to make my own stuff and was just looking for ideas
Old 01-31-2008, 06:36 PM
Wiki Edits: 31
did you disable the idle circuit on the rear carb? that has to be done. Multiple carbs also have to be synchronized
Old 01-31-2008, 07:45 PM
F&J F&J is offline
Well, those facts are true But! Idle circuit on one being shut off is true only if it has progressive linkage.
2 carbs DO need sync IF they are running non-progressive linkage.
I think maybe what you meant is like on trips with progressive, THEN you want to sync the 2 outboard carbs at high rpm.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
700R4 fit behind a chevy 235 straight 6? panamracer Engine 3 01-02-2007 08:24 AM
Chevy 235 monojet question garretthes Engine 3 02-13-2005 04:25 PM
Chevy 235 lifters? OldCarPilot Engine 3 01-29-2004 08:11 AM
dual carbs???????? neil madsen Engine 3 10-31-2002 04:50 PM
