Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 235 engine lifters
Old 07-01-2012, 10:24 AM
matt167 matt167 is offline
Wiki Edits: 31
New lifters can be added to an old cam. It's done all the time if a lifter goes flat and stops pumping up.. You can't run old lifters on a new cam.. After the lifters are replaced, the cam should be gone thru a basic break in procedure to pattern the lifters to the cam..
New Cam wouldn't be a bad idea. Cost of a cam and lifter kit isn't much more than the lifters itself
