Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 235 engine lifters
Old 07-01-2012, 05:00 PM
lilrobo's Avatar
lilrobo lilrobo is offline
thanks matt
i will get on the phone to find lifters come mon ... i hate to keep running in circles with adjusting worn lifters you know ,, the outcome will be the same ,, i thought for sure after i cleaned everything it would fix the noise , its over 100 degrees here , i was going to put the valve cove and go around the block ,, and see what happens ,,, but i believe the same out come ,, i will get a set and see from there ,, i'll keep you guys posted ,, i have a couple of places to call
thanks again
