235- intake/ exhaust manifold removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2012, 05:39 PM
Wiki Edits: 31
Putting on a new exhaust head pipe on my '51 Chevy 235, and even with days of penetrating oil and 50/50 acetone and ATF, and getting the engine hot before trying to remove the bolts, both snapped. kind of expected it, and given that both bolts rusted to 1/4 of there original diamater where the gasket was. not even heat would have fixed it.. tried to drill the bolts out from underneath but it's way too tight. So my only option is to now remove the manifolds, and then I'll have room to do it right and try to chase the original studs out, or drill to the next size if I have to..
Any insight before I crack any bolts loose? I have the gaskets on order from my local CQ, but it looks like the intake/ exhaust use the same gaskets and theres 3 seperate gaskets.. Choked correctly for ambient temp. the engine runs like a swiss watch.
Old 03-15-2012, 06:43 PM
LATECH's Avatar
you could pilot drill both broken bolts , then pound a square easy out in, then heat blistering hot around the hole with the acetylene torch, they may back out easy. You will no doubt ruin 2 easy outs but it may be the least painful way out.I have extracted bolts that way before.
Old 03-15-2012, 06:59 PM
Wiki Edits: 31
That's kind of along what I was thinking.. I would have fired up the torch under the car, but the gasket on the oil canister blew out ( not tight enough ), and it's well lubricated under there now. I'v since fixed the gasket and the engine never lost pressure, but havn't cleaned up the quart of oil it left behind before I noticed it...
It's bad enough that, to replace the radiator hoses, you actually need to remove the radiator, loosen the powerglide cooler so it can swing out, and then fight with the hoses.. took me an hr being careful, and I did damage the hose end of the powerglide cooler by spinning a deteroriated hose with a pipe wrench, but it doesent hurt the function.. removing the manifolds just adds to it.. but I'd rather do it up right
389 4 barrel intake manifold removal Billysteez Engine 21 04-29-2010 09:55 AM
Should I block off the exhaust passages on my intake manifold? Arrowhead Engine 1 08-21-2008 09:04 AM
Intake manifold exhaust connection rsk289 Engine 3 07-20-2008 11:46 AM
55 Chevy 235 Split Exhaust Dual Intake Manifold drdislovely@aol.com Introduce Yourself 3 11-02-2005 01:19 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
