239.4 In A 37 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2004, 10:25 AM
MARCELO URUGUAY's Avatar
New Member
Question 239.4 In A 37
PLEASE HELP ME PUT A 239 FLATHEAD IN MY '37 FORD COUPE!
IS THERE ANY WAY TO KEEP THE ORIGINAL FAN?
THE REST OF THE COUPE IS IN ITS ORIGINAL FORM SO I DON`T WANT TO USE AN ELECTRIC FAN
Old 11-03-2004, 11:09 AM
poncho62's Avatar
Wiki Edits: 5
welcome............it should fit right in, they came with flatheads in 37.
moving to engine forum.
Old 11-03-2004, 11:49 AM
New Member
Unhappy BUT 49 TO 53 ARE LONGER
THE 49 TO 53 FLATHEAD FORD IS AT LEAST 5 INCHES LONGER THAN PREVIOUS FLATHEADS DUE TO THE SLANT MOUNTED DISTRIBUTOR, THE FAND AND PULLEYS. WHAT CAN I DO TO MAKE IT FIT WITHOUT USING AN ELECTRIC FAN?
Old 11-03-2004, 07:06 PM
Marcello, even though the Distributor is topside, it is gear driven off the end of the camshaft as was the older versions. The length of the newer pulley/fan assembly is almost identical to the older because it had to clear the big double capped distributer. If you have the original fan generator set up for the 49-53, you should be able to fit it in with no problem. If you don't have the bracket, gen. and pulley, then you will need to go after market. Let me know if you don't have what you need and I may be able to help you out. Years ago, this was a common engine swap because of the improved distributor location and additional 15 to 25 HP gain.
Trees
Old 11-03-2004, 09:32 PM
A '37 Ford just ain't right if it's not powered by a big block chrysler
