23T Hub and Disc Brake
I have a 4" dropped tube axle with bare 37 to 41 Repro Ford spindles. Any ideas on what can I use for a good hub and disc brake setup which will bolt right on. The kits are way out of line and I was hoping someone might have an idea on a good setup which I could scrounge from a wreckers or parts car or where I might get some plans/templets to make adapters.
You can buy the kits reasonably priced at www.speedway.com. The kits come two ways..with everything, and with everything except the rotors, and calipers. So if you can get them cheaper elsewhere it would save you a little.
Dee004
Thanks for the info guy's I appreciate it. I'll probably go the aftermarket route as I want to get this chassis rolling ASAP.
| 63 impala simple disc conversion | PikFabrications | Suspension - Brakes - Steering | 21 | 01-05-2008 02:12 PM |
| 31 ford disc brake suloution | WilderRods | Suspension - Brakes - Steering | 2 | 05-01-2005 06:31 PM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| 65 Mustang, 6 cyl. Disc brake conversion? | Rugbywinger | Suspension - Brakes - Steering | 1 | 01-10-2003 09:38 PM |
| Drum to Disc 70 C-10 | slider | Suspension - Brakes - Steering | 1 | 11-02-2002 06:15 PM |
