24v jeep generator
Hey guys, my neighbor has a 1953 M38A1 Jeep. It uses a 24v electrical system, and everything is sealed for underwater usage. The voltage regulator box is external mounted, but the system is not charging. There is a bulkhead connector that screws water tight which goes from the back of the generator to the regulator. Inside this connector are 3 pins, we put my DMM on the back of the generator to try to get some sort of reading, not knowing what each pin was suppose to read, we tried every combination we could think of from using the casing and each pin as a possible ground. This was done while the jeep was running and tried at different RPM's. We got nothing from any of the combinations, every once in a while it might read 3.5v, nothing close to the 24-28 as stated on the casing. There is a tag saying it was rebuilt in 1975, but it spun freely with the belt off with no squeaking, or any hard resistance while turning. So, we took it out and pulled the the guts out of the casing, all of the connections of the wires looked to be connected securely, not corroded up real bad or anything, the burshes had lots of material on them, but a bit glazed. We scuffed them up, maybe thinking that might help. Still, after reassembly, nothing seemed to work. It looked to be a very simple unit with no capacitor or anything on there, just the windings, armature and brushes, and the wires. It looks like it should work, putting out voltage all the time and the regulator doing all of the dirty work.
Does anybody have experience with any of these old jeep regulators or any 24v generator systems that are similar? Maybe there is a better train of thought and process of elemination that is eluding us? But so far, it looks like it's just the generator that does not work, and it "appears" as if it should.
Thanks guys!
