25 amp Moroso toggel switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2008, 03:06 PM
Hi Guys,
Here's what I want to do. Tell me if it will be ok.
From the + side of the Ford solenoid I will be running an 8 gauge wire to a
aux. fuse box. From one of the 20 amp fuses I will run a 10 gauge wire to a 25 amp Moroso toggle switch. From this switch I will hook up my MSD digital 6 box. I will also run a jumper wire to one side of my push button starter. So now I switch the toggle up, I have ignition. Push the button and I have start. How does that sound? Or maybe a 40 amp fuse from the fuse box and a 50 amp toggle switch Might be better? What do you guys think? Thanks in advance.
Thom
Old 10-31-2008, 04:57 PM
Wiki Edits: 31
the MSD box should have a seperate wire that triggers an internal relay aside of the main 10 ga power wire, that you hook to your ignition source. you don't need a super duty switch to trip a relay. as for the jumper wire to a push button. the ford solonoid is only a relay. that'll be fine.
Old 10-31-2008, 06:49 PM
Thanks!!!!!!!!!!!!!!!!!!!
Old 10-31-2008, 09:19 PM
302 Z28's Avatar
Matt nailed it, good advice .
Vince
headlight switch or dome light? hoffmandirt Electrical 1 06-30-2008 10:56 AM
Wiring Neutral Safety Switch / EZ-Wire Kit horvath Electrical 15 01-20-2008 12:35 PM
ac to dc amp rating HELP???? Ratchet Electrical 7 01-23-2006 04:53 PM
100 AMP Service In Garage Help daveh Garage - Tools 9 02-27-2005 01:15 AM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
