#1
250 & 292 in line sraight differances
I have 64 chevy PU . thought it was 250 . i had the head redone . put back together with 250 gaskets kit . runs very bad . blowback pressure very bad .
Now i know its a 292 i think also at origanal was a LPG engine. Any one know if it needs differant gaskets on this set up ? Register now (free) or login to remove ads |
#2
Check the parts books at your parts store. Ideally Napa or someplace old with stacks of old parts books. Computers only go back 20 years or so.
#3
The head and related gaskets are the same for 250 and 292. The block, side cover, and crankshaft and rods are the only parts that don't interchange.
If you have a 292, the passenger side motor mount is not directly opposite the one on the driver's side and on a 250 it is. |
| Thread Tools | Search this Thread |
| Similar Threads for: "250 & 292 in line sraight differances" | ||||
| Steering leak where rubber line meets metal line | bigdog7373 | Suspension - Brakes - Steering | 2 | 06-24-2011 07:26 PM |
| Best fine-line tape and tips to make a perfect line. | smithkustoms | Body - Exterior | 9 | 03-24-2010 11:29 AM |
| Sraight axle | Free Bird | Introduce Yourself | 4 | 07-22-2009 07:54 PM |
| 3/8" female to male flex line needed. Any cars front wheel cylinder frame line? | Ripped | Suspension - Brakes - Steering | 2 | 03-12-2008 02:47 PM |
| FUEL LINE & TRANS LINE SIZE/TYPE | leejoy | Hotrodding Basics | 7 | 11-29-2005 10:59 PM |
