250/Powerglide into '62GMC PU - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2013, 04:05 PM
I've got a '62GMC PU which I just inherited.
It's got the original 305V6 w/4speed, but it spun a crank bearing. No good.
I don't want to rebuild this motor as it's not high value and a gas hog. My hope is to turn the truck into a decent driver with some pep to it. No racer, just a fun cruiser.
I've a 250straight6 w/power-glide from a '68Nove 4-door that an uncle says should drop right in.
Is that correct?
Old 05-05-2013, 04:32 PM
vinniekq2's Avatar
hardly peppy,will fit
Old 05-05-2013, 04:35 PM
Yeah, I know it's not all that powerful. But I'm now looking for a powerhouse with this truck. More a decent cruiser that'll do good on the highway too.
Will I need to do anything with the crossmember or the trans mount?
Old 05-05-2013, 04:38 PM
Is that correct?
Wasn't that drivetrain installed in the equivalent 1962 Chevy pickup? You might need the Chevy mounts.
Old 05-05-2013, 04:59 PM
The little info I've got says it was. The hot rodder uncle in the family says it'll go right in.
I just wanna check around before doin this. I tend to get a bit aggravated when I run into unforeseen complications. Nothing quite like having to undo everything because a little something or another wasn't gotten or done beforehand. It still happens, but I like to minimize that as much as possible.
Old 05-05-2013, 05:33 PM
RWENUTS's Avatar
THe chevy in 62 would have been a 235. Different motor mounts. You might need to fab some or modify the ones on the 250. Tranny crossmember mount needs to be removed. It's in the way for the tranny to fit right. You'll need to make one for the back of the glide.
It's doable but not a bolt in.
The Following User Says Thank You to RWENUTS For This Useful Post:
ancientx (05-05-2013)
Old 05-05-2013, 08:04 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Several places make universal trans cross members, try TransDapt for one, they have some with drops, straight, etc.
Crossmembers
Check out eBay as well.
Semper Fi
The Following 2 Users Say Thank You to 68NovaSS For This Useful Post:
ancientx (05-05-2013), Crosley (05-05-2013)
Hi, I'm new. '62GMC advice welcome. ancientx Introduce Yourself 4 05-05-2013 10:01 PM
S-10 T5 to 250 I-6 myascape Transmission - Rearend 3 03-31-2012 08:44 AM
'67 250 cid powerglide bolt up to SBC ? adantessr Transmission - Rearend 4 11-01-2011 07:41 PM
250 into 52 32boom Engine 5 12-01-2009 04:53 PM
